VDC-то не можеш да го изключваш и за него си имаш отделна лампа на таблото която светва при даване на контакт/ако е монтирано такова/. за другото до скоростите все ASR трябва да си пише/разбира се ако я има/. ето какво пише в книжката на потребителя
Quote:
ASR FUNCTION (ANTISLIP
REGULATION): GENERAL
The ASR system integrates the VDC system
controlling the vehicle drive and coming
into operation automatically each
time one or both driving wheels skid.
Two different control systems are activated,
depending on the skidding conditions:
– If skidding concerns both driving
wheels, because it is caused by the excessive
power transmitted, the ASR system
cuts in reducing the power transmitted by
the engine.
– If skidding concerns only one driving
wheel, the ASR system cuts in automatically
braking the skidding wheel, with an
effect similar to that of a self-locking differential
Quote:
The action of the ASR system is particularly
helpful under the following conditions:
– Skidding of the inner wheel on a
bend, due to the effect of the dynamic
changes of the load or over-accelerating.
– Excessive power transmitted to the
wheels, also in relation to the conditions
of the road surface.
– Acceleration on slippery, snowy or icy
surfaces.
– In the case of loss of grip on a wet
surface (aquaplaning).
а ето и защо може да се изключва ръчно
Quote:
TURNING ON THE ASR
FUNCTION
The ASR function turns on automatically
each time the engine is started.
When travelling it is possible to switch the
system off and on again pressing the switch
(A-fig. 144) on the centre console.
The warning light (B-fig. 144) on the
switch turns on to indicate that the system
is off.
If the function is turned off while travelling,
it will turn on again automatically
the next time the engine is started.
IMPORTANT When driving on snow,
with snow chains fitted, if may be helpful
to switch off the ASR function: in these
conditions in fact, skidding of the driving
wheels when moving off helps to obtain
better traction.
