Може би новите мотори не са чак толкова кашкавал колкото си мислим - 1.6 Gamma T-GDI (G4FJ),It is a version of 1.6 Gamma GDi with twin-scroll turbocharger, air guided intercooler, direct fuel injection system and dual CVVT.,Gamma 1.6-liter 4-cylinder direct-injected, turbocharged engine generating 175 horsepower at 5500 rpm and 195 lb.-ft. of torque from 1500-4500 rpm, an advantage over its key competitors. Peak torque delivery starts at only 1,500 rpm and holds through 4,500 rpm, for low-RPM responsiveness and performance in everyday driving conditions. The turbocharger features low-inertia turbo-spooling response characteristics and an electronic wastegate control for more precise control of manifold pressure. Internally, piston-cooling oil jets ensure cooler piston temperatures for enhanced engine life. The Gamma engine also features a water jacket insert that prioritizes cooling in the upper level of the cylinder block where more combustion heat is generated, resulting in lower cylinder-head temperatures and allowing for leaner air/fuel mixtures for better fuel efficiency."
Второ - тарикатите ти дават обслужване на 15 000 км. за да си гарантират че мотора ще е наред и 5 годишна гаранция НЕЗАВИСИМО от изминатите км.
Това ми е първата нова кола така че и на мене ми е много интересно как се случват нещата.
