Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: water injection
    Default water injection
    Какво ви е мнението за водно-метаноловата инжекция.Има ли смисъл става вапрос за алфа 159 1.9Jtdm 16v .Как ще се отрази на DPF филтара , има ли риск за двигателя някои поставял ли е такава система в България
    ето линк към кита http://www.coolingmist.com/
    Mar 2008
    Горна Оряховица
    40
    7,474
    Първо мисля да си зададеш въпроса кога е нужно инсталирането на такава система и защо. И при кои двигатели.
    In internal combustion engines, water injection, also known as anti-detonant injection, is a method for cooling the combustion chambers of engines by adding water to the cylinder or incoming fuel-air mixture, allowing for greater compression ratios and largely eliminating the problem of engine knocking (detonation). This effectively increases the octane rating of the fuel, meaning that performance gains can be obtained when used in conjunction with a supercharger or turbocharger, altered spark ignition timing, and other modifications.
    In a piston engine, the initial injection of water cools the fuel-air mixture significantly, which increases its density and hence the amount of mixture that enters the cylinder. An additional effect comes later during combustion when the water absorbs large amounts of heat as it vaporizes, reducing peak temperature and resultant NOx formation, and reducing the amount of heat energy absorbed into the cylinder walls. The alcohol in the mixture burns, but is also much more resistant to detonation than gasoline. The net result is a higher octane charge that will support very high compression ratios or significant forced induction pressures before onset of detonation.
    Fuel economy can be improved with water injection, although the effect on most engines with no other modification, like leaning out the mixture, appears to be rather limited or even negligible in some cases.
    Some degree of control over the water injection is important. It needs to be injected only when the engine is heavily loaded and the throttle is wide open. Otherwise injecting water may simply drown the engine and cause it to quit.
    Direct injection of water is possible. In a piston engine, this can be done late in the power stroke or during the exhaust stroke.
    A limited number of road vehicles with large-displacement engines from manufacturers such as Chrysler have included water injection. Saab offered water injection for the Saab 99 Turbo. With the introduction of the intercooler the interest in water injection disappeared, but today, water injection is also of interest because it can potentially decrease nitrogen oxide (NOx) emissions in exhaust. The most common use of water injection today is in vehicles with aftermarket forced induction systems, such as turbochargers or superchargers. Such engines are commonly tuned with a narrower margin of safety from detonation and hence benefit greatly from the cooling effects of vaporized water.
    http://www.facebook.com/TempoGarageSofia
    циничен ницшеанец търтей's Avatar
    47
    7,058
    Е те на това се слага водна инжекция (50 вода 50 метанол)
    М да и аз го прочетох в wikipedia.Вапроса ми е някои пробвал ли го е и сакращава ли мн живота на двигателя.Изчетох доста матеряли по вапроса и ми е интересно дали ако го сложа на моята кола 6те имам проблеми
    Mar 2008
    Горна Оряховица
    40
    7,474
    Слага се на ето това. http://www.youtube.com/watch?v=4wTEZ0gX1hE
    JTD проповедник trustworthy's Avatar
    Варна
    5,167
    Щом си го чел, значи трябва да ти е направило впечатление, че е станало дума за ОКТАНОВО число, а не за ЦЕТАНОВО. Виж и за тях какво пише в уйкипедия и кои видове горива характеризират
    _______
    146 JTD - ex
    47
    7,058
    Чел си дедовия. Още по правописа ти виждам колко и какви книжки си чел.
    The increased power could be used for a maximum of 10 minutes at a time, with at least five minutes between each application.
    http://www.youtube.com/watch?v=8sVNij1iekw
    и все пак за или против и защо?
    Mar 2008
    Горна Оряховица
    40
    7,474
    Това се инсталира при бензинови мотори. И то много напомпани турбо мотори или мотори с много висока степен на сгъстяване. Тази система се ползва за намаляване температурата в горивната камера, но и забавя процеса на горене.
    Има много плюсове при много тунинговани двигатели и много минуси при нормални двигатели. Общо взето да го сложиш да сток мотор, освен да се влоши горенето, друго няма какво да стане.
    И не се монтира на дизели ако това питаш.
    Quote Originally Posted by oem View Post
    Това си е за бисерите на форума...нищо лично.
    А по темата:
    Можеш да си го инсталираш без никакъв проблем, ще получиш много малко увелечение на мощността, НО ако решиш да си направиш и ремап нещата стават коренно различни.
    Иначе тази система е перфектна за DPFфа, защото почиства целия мотор перфектно!!!
    Най-бързата Българска Алфа на писта 147QVD, 159 2.4QVDm, Crosswagon Edition Nero, Aprilia SR 50 Tetsuya Harada Replica
    " Marco Cavigioli champion IRC 2WD with Fiat Grande Punto DIESEL"
    "Seat Leon TDI champion WTCC 2008"
    Mar 2008
    Горна Оряховица
    40
    7,474
    Щом така смяташ...
  13. #13
    кара на Зсссгъстен въздух drigata's Avatar
    Jan 2007
    софия
    46
    1,573
    Виждам,че тука много хора се опитват да разберат за какво иде реч,но не сте стигнали до най важното.
    Това което е постнал НЕО е за разработките през 60-те години,когато е имало голяма борба с детонацинното горене.
    А същноста на съвременните мотори и водна инжекция е ,че сегашните разработки на двигатели са избегнали проблемите с детонациите и работят с много по висока степен на сгъстяване и прибавянето на водна инжекция може и ще допринесе до по голяма мощност и въртящ момент,поради простата причина,че водата подложена на висока температура и налягане се разпада на основните си елементи,водород и кислород.
    Смятам ,че и сами знаете какво ще се получи когато в даден двигател пренодително се "набута" още кислород ,а да не говорим и за водорода.
  14. #14
    Оф все се надявам да сваря да я монтирам по скоро, намерих си резервен колектор за 2.5, утре даже мисля да го занеса с една дюза за образец да го пробия и навия резба, и да шерна отзиви какво става като се сложи на атмосферка......
  15. #15
    Jan 2008
    5,265
    Айде Ники ще чакаме включване ( с голям интерес следя темата)
    МEGANE RS CUP ''20
    Alfa Romeo 156 SW 1.9 JTD
