Piaggio Liberty 05" 50cc 2T
Този, който изписва всичкото инфо - радиостанция, съобщения, температурата и т.н. Цена?
Забравих, специално за всички със 147 и боди компютър, а и за да прекратя вече безмислените спорове къде е алармата и нападките по този повод с/у мен:
Description от E-Learn
The intruder alarm system offers volumetric and perimeter protection.
A control unit (inside the Body Computer) controls - Централата (вътре в Бордовия компютър) контролира:
- status of doors, boot and bonnet via switches in the locks (perimeter control);
- the presence of a moving object inside the passenger compartment, via volumetric sensors. (volumetric control)
- the condition of system supply leads;
- operation of the ignition switch.
The control unit is equipped with an autodiagnostic function which detects and memorizes faults in the control unit itself and the system components; it also checks the condition of link cables and stores the number of activations and the number of alarms.
The control unit operating software may be altered to meet regulations governing the use of alarm systems applicable in different markets.
For more details Characteristic of working principle 5580E anti-theft device .
The alarm siren is located at the front, under a Locary on the left of the engine compartment.
The remote control system consists of a sending unit built into the key and a receiver built into the Body Computer.
The same switches as for the central locking system are used to control the doors and lids. A special switch detects bonnet closure. (A buzzer goes off if the body computer detects that one of the doors or the boot is open and the car is travelling faster than 3 km/h).
The volumetric sensors check for car intruders. They are located in the two centre pillars. Both are twin sensors, i.e. consisting of an emitter and a receiver: the wave transmitted by an emitter should reach the receiver of the other sensor and viceversa: if this is not the case, an alarm signal is sent to the control unit.
The deterrent LED is located on the central control panel and indicates the state of the system (on, off, etc. ) plus any faults.
All external components are connected to the Body Computer via a dedicated serial line.
Нарочно не го побликувах по-рано. Просто исках да видя до къде ще стигне на някои наглостта, безочието и високомерното незнание.
А, да... и всички 147 имат боди компютър, а аларма - в зависимост от програмата, с която е зареден този елемент и дали е активирана софтуерно
Сега, последно за алфа 147, някои имат а други не, така ли да го разбирам?
Това копче, с което се заключва колата, задейства ли и някаква защита против кражба и макар да не се чуе алармата, ще блокира запалването, или си е само централно заключване и никаква аларма?
До сега не съм имал кола без аларма, та си викам - има си аларма колата, ама в тая-оная тема гледам, има, ама може и да няма, та наострих уши
като чета това-онова пък се оказва, че ако отида да поставям може да се вкарам в кофти филм, дори откавали да поставят на алфи с фабрична аларма, макар, че хората при които ходя не са слагали само на космическа совалка и то не за друго, ми щот ногу бързо фърчат
Ако имаш 156 фейс, точно пред екранчето на инфодисплейя трябва да има едно червено диодче, ако имаш аларма...
OEM & Ventura Garage
Още едно нещо което сега научих на колата си!Страшно много се кефя на тази екстра,защото точно такова ми трябваше,а не да цъкам дистанционното постоянно за да ми светват мигачите докато си заключвам гаража.
Alfa Romeo 147,1.9JTD(115hp)
Искам да ти се извиня публично пред целия форум,по темата за алармата отчасти не бях прав.Попрочетох днес някои неща и разбрах че за Германия,но само за там е слагана вградена програмируема аларама.Другите които се монтирали в Италия и швейцария са външни,защото там както каза Марто,алармите на са много разрешени,и е ставало по желание на клиента.Пак са монтирали оригинална аларама,но външна с надпис Алфа Ромео,каквато имам аз от нашата 147..............
П.С.Мисля с това споровете и най-вече нападките да приключат
Добре, мисля се изясниха нещата, така че моля вече само по темата.
Така...да питам нещо, колеги! Значи имам функцията на 147-та за изпращането до вкъщи, има и функцията за отварянето на прозорците при отключване. Обаче не иска да ги вдигне после от дистанционното при заключване. Програмира ли се това по някакъв начин да се случи за вдигането или няма шанс? И другият ми въпрос е дали при отключване на колата може да се направи така, че фаровете да светнат? Мерси!
По предишните въпроси не мога да помогна. Преди години на 147-цата ми се сваляха само стъклата, но се и вдигаха от дистанционното. Както и при теб. Не бих се учудил, ако е някаква защитна мярка против евентуално затискане на нещо / някой с прозореца. Както е при пасажерския прозорец.
Но виж - за последния ти въпрос, аз се бях замислил оня ден. Не съм наясно с токовете, но като се замисля follow me home функцията при повечето други коли е при отключване и заключване на колата. Ако фаровете се вържат към централното, да сработват с отключване и заключване на колата и да минават през реле май би трябвало да стане???
'06 Alfa Crosswagon Q4
И аз съм доста скаран с токовете. А твоите как се вдигат като заключваш? Задържаш бутона за заключване или само го натискаш и пускаш?
Не се вдигаха изобщо. Нито с едно натискане, нито със задържане. Само можеха да се свалят.
