Нов софтуер за връзка с ECU - FiatECUscan
    Няма да стане с този кабел
    Благодаря, колега! Би ли ми дал линк към кабел, с който става?
    Alfa Romeo 156 2.4 JTD Distinctive 00' - EX
    Alfa Romeo 156 2.4 JTD M-Jet 20V Distinctive 04' - Now
    Toyota Avensis 1.6 D-4D Executive 15' - Now
    • Първоначално публикувано от melenikos Покажи съобщение
      Ето това ти трябва http://sklad66.com/cms/VAG-COM.html
      Alfa Romeo 1.9 JTD 00 sigpic
      • Първоначално публикувано от myato Покажи съобщение
        Мерси, за линка към кабела!
        • От днес е налична нова версия 2.7
          19/02/2011 - Version 2.7 - Fixed a problem with Remote Control programming
          - Fixed the RPM calculation in Bosch Motronic ME7.3H4
          - Support for TRW MY05, AUTOLIV MY06, AUTOLIV MY07 and SIEMENS MY06 Airbags (Grande Punto, Punto Evo, 500, QUBO, MITO)
          - Support for Hitachi MPI Injection (pre-98 vehicles)
          - Support for Bosch Monomotronic MA1.7.3 Injection
          - Added [Recent] option for vehicle selection
          - Added search when typing for vehicle selection
          - Added "tool-tips" for the buttons. The messages for the tool-tips can be modified/translated from the language files.
          - Added Select All/Select None buttons on Parameters screen
          - Added monitoring of error codes in Parameters and Graph screens and recording of the error codes in the generated CSV logs.
          - Fixed a problem with the scaling on the graph screen.
          - Added current values display on a graph when the user clicks on it with the mouse.
          - Improved PROXI procedure support
          - Added more configuration options for PROXI procedure (Stilo, Punto, 147)
          - Added command-line switch /t=XX where XX is a template number. This switch causes the program to connect to last ECU and load the selected template. (So, when you run "FiatECUScan2 /t=1" then the program will start, connect to the last ECU, go to Parameters screen and load template 1.)
          - Added interface auto-selection. You can define up to 4 interfaces in Settings. Then when you click "Connect" the program will first check which of the interfaces is connected to the computer and will use that interface for connection to the vehicle. If there is only 1 interface defined in Settings then the program works without auto-selection.
          - Added interface lookup function in Settings. This function will automatically identify the type of interface, port and port speed of your interface(s). The interface has to be powered (connected to vehicle).
          - Added full support for the USB OBDKey 1.40 interface which is in official production now. This interface cannot be used for Fiat Grande Punto, Alfa MITO and Fiat 500 yet.
          - Added support for the Bluetooth OBDKey 1.40 interface. There are still some stability issues with the Bluetooth interface, so the USB unit is recommended.
          - Added "PLEASE CONNECT ADAPTER XX" messages before connecting to ECU. For the users who do not use adapter cables the message can be disabled from Settings.
          • Някой знае ли кодовете на грешките за "фиат еку скан" ?
            Примерно нещо като "пдф" или "ексел" фаил като срещу всяка грешка е оказано за какво става дума. Гледам че програмката дава някакви указания при наличието на грешка, както и предполагаеми причини, но все пак ...
            • Първоначално публикувано от mirchozo Покажи съобщение
              Не ти трябва колега.В клетката на края на реда се описва каква е грешката.
                Заповядай колега. Ще почерпиш
                безплатни обяви
                Моята 166
                • Първоначално публикувано от kolioto Покажи съобщение
                  С този кабел някой пробвал ли е програмката:
                  http://sklad66.com/cms/VCDS-VAG-COM.html
                  нешто не мога да се вържа!?!
                  О тука http://www.ftdichip.com/Drivers/VCP.htm сваляш драйвери като за твоята ОС. После от тука http://www.ftdichip.com/Support/Utilities.htm търсиш Microsoft USBView. Включваш си кабела в свободен USB, пускаш програмката и гледаш за неразпознато устройство, посочваш го, вдясно ти излиза купчина с данни, търсиш idVendor и idProduct. Запиши си стойностите срещу тях. Следващата стъпка е да идеш при свалените драйвери и да намериш ftdibus.inf и ftdiport.inf . Там заменяш оригиналната стойност на VID с тази записана от idVendor, съответно същото и за PID и idProduct. Стъпка следваща четеш от тука http://www.ftdichip.com/Support/Docu...r_Windows7.pdf как се инсталират драйверите за USB serial port. Това за вин7.
                  При мен стана с такъв кабел.
                  Сърцата са по-капризни от умовете.
                  • Колеги здравейте!
                    Имам някакъв проблем с ФЕС, връзвам се към еку-то на ДВГ, но към АБС или Еърбег немога да се закача!
                    Пробвах на Алфа 145 и на ГТВ, но не става! И двете са с 3 пиновите букси! Иначе си правя и мостчетата за АБС И Еърбег!
                    Някой ако е имал подобен проблем да сподели как го е оправил!
                    Alfa romeo 33 1.7 8V - the monument and Alfa Romeo 156 1.9JTD
                    • Първоначално публикувано от Събев Покажи съобщение
                      Колеги здравейте!
                      И аз имам този проблем. При мен и 3 пиновите и обд2 не мога да закача абс-а. Интересното е при мен на 155-цата, примерно ми светва лампата, като че съм се закачил, но реално софтуера казва че не съм... нямам още отговор за проблема.
                      Alfa Romeo 155 1.8TS by RuBig
                      Volvo V50 2.0D by RuBig
                        Колеги здравейте!
                        Проблемът е в това,че софтуерът не поддържа по-старите централи.Някъде в сайта на FECUS пишеше по въпроса.
                          Ще пробвам на по-нова кола да видя как ще е!
                            Ако пробвате с модефициран кабел за АР156.
                            Пиновете на преходника 3 към 16 не отговарят....
                            Само 7 пин отговаря...
                            GT- JTDm 150
                            • A сега какво беше
                              пин 1 - ABS
                              пин 3 - Аirbag
                              пин 7 - ECU
                              пин 8 - имобилайзер (ключ)
                              пин 9 - климатик
                              По-новите версии имат ел. усилвател (волан), табло, др.
                              Инфоцентър дисплеят има куплунг В57 за диагностика при бушоните, ма никой няма сведения как и с какво се действа там. Дори и Милано мотърс. Ако някой знае - да пише
                              • Въпрос за грешка на Airbag
                                Здравейте колеги, преди време бях забравил да закопчея волана от лостчето под него, и докато си изкарвах колата от гаража лампата на възд. възглавница светна. След дълги наканяния реших да си купя кабел за диагностика и да си премахна грешката. До тук всичко ок , закачих я с мостчетата и като дам на Fiat Ecu Scan да се сварже с компа дава грешка, пробвах и с AlfaDiag. Ако някой може да помогне по въпроса ще съм много благодарен. Колата е 156 1,8ТС '98г.
