Tempra 1.5 Turbo
  • #61
    Bought knuckles for Alfa Romeo 155 2.5V6 and shock absorbers Fiat Marea.
    • #62
      Колега пиши си на руски ,махни ги тези неграмотните англофили.
      155 2.0 16v МY95 Sport
      • #63
        Made a spacer under the oil filter. Fence on the turbine oil from the main oil gallery. I think the oil pressure is higher, the turbine will be better)))
        • #64
          Don't You thing that the oil filter is near to the exhausted tubes ?
          • #65
            Първоначално публикувано от stelt Покажи съобщение
            small optical illusion))) from the filter to the exhaust manifold - about 12 centimeters. I think it is not critical, later made thermal screen.
            PS: I'm more concerned located close to the exhaust starter))) but for him to do thermal screen
            • #66
              Put forged wheels. Like appearance?
              • #67
                The car is in very high standing position ... is it jacked up ?
                • #68
                  Yes, the car in a high position. I think it's because of the Fiat Marea 2.0 racks. There's a heavy engine, and therefore higher and stiffer springs. I have the same engine much easier, hence the result))) For the first time enough)))
                  • #69
                    If the car is done for drag, you better stick to stiffer and longer springs at the back, but the front ones are usually short and stiff.
                    • #70
                      hi there! Faced with the problem that in the engine compartment to fit downpipe. I think to solve this problem by setting the hot turbine housing from the Alfa Romeo 164 turbobenzin B6. It is very compact and small. I think it is much setting free the space under the hood. A / P far as is known to me - 0.41; 6 centimeters. I think it will speed up the spool.
                      • #71
                        несколько фото
                        • #72
                          развитие по темата ?
                          • #73
                            коллеги, подскажите. Кто-нибудь использовал выхлопной коллектор от фиат крома турбо 8v?
                            • #74
                              кстати, сделал топливный насос. Насос от MMC Evolution 8.
                              • #75
                                привет всем! Обновлю немного. Сделал всю трансмиссию, положил проводку, подключил бензонасос, сделал даунпайп.
